dhaccordLT-R
ok, this has me stumped, its probably something dumb, but here goes> on the back of the tranny where the shift linkage meets the tranny, (right above that area), there is a weird sensor/valve that has a tight rubber o ring around it, is cylindrical in shape, has two bolt holes that bolt downwards into the top of the tranny(5speed), and it has a needle valve type device that easily pulls out and it only will fit in one way. this part i am talking about is the only part on that area of the tranny. i really need help on this one. also, my swap didnt come with the ecu unfortunatly, i found a used p72 for $200, is it worth it or should i just buy a skunk2 for $275? is there anything that i should check for on the ecu?
