97reddelsol
Hey everyone i have a 97 gsr trans on a 95 gsr motor in a 97 DEL SOL and it will not shift into gear while the car is running. When the car is not running it shifts smooth into every gear. I have a New Fidanza 7.5 lb flywheel, oem honda clutch and a used ACT pressure plate. New OEM pilot bearing, OEM throw out bearing, New shift for and spring all OEM. I have a new OEM vtec b16 del sol shift linkage. Ive bleed the clutch lines a total of 3 times now i adjusted the part on the Clutch master Cylinder that goes to the pedal and you put the pin through to it is closer to the pedal trying that. I got the trans in about an hour go and still wont shift into gear while running. I Put it in reverse and then started the car and with the pedal fully pushed in it jerked and i threw it into neutral not wanting to fuck anything up. Please help. And the car motor wiring and everything is good. Just the trans is fucking killing me.
Thanks Jayden
Thanks Jayden
