guage lights
Discussion in 'General Tech and Maintenance' started by ghsbaseball91, Jun 28, 2008.
  1. ghsbaseball91
    ghsbaseball91 New Member
    Catawba, Virginia
    i have asked about this before but in my 93 sol the white face gauges flicker sometimes...and someone said check the connection but i didnt put them in so i dont kno what to check
  2. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    Get a haynes manual.
  3. ghsbaseball91
    Catawba, Virginia
  4. BrutalB83
    Rochester Hills, MI
    Haynes, Chilton, whatever...he's talking about the manuals you can buy at auto parts stores, the have wiring diagrams in them...
  5. ghsbaseball91
    Catawba, Virginia
    ooh ok so i can jus go up to advance and grab one?
  6. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    Bingo! :D
  7. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    you gotta go up under your dash and find the guage insert regulator box that all the wires go into. it's fairly easy to locate the wires for the guage inserts usually as they're normally 3, 2wire wires. they all feed to a box, which wires into the power.
  8. Bkkfarang
    Bkkfarang New Member
    Bangkok and Shenzhen
    light flicker , loose connection , or bad ground , keep searching and good luck
  9. ghsbaseball91
    Catawba, Virginia
