Quoted post[/post]]
wiring is going to be hell
H22's only came OBD 1+
DA tegs are OBD-0.
I know the wiring gets to be a pain on OBD 1 civics and such so I can only imagine what it would be on a DA.
I think that 7K budget is going to be difficult. I spent almost 2K on a B16 swap just fixing random stuff and such.
1500 for motor, shift linkage(mine was trashed) and shipping
50 bucks water pump
40 bucks timing belt
60 bucks timing belt tensioner
motor mount inserts=30 bucks
shifter bushings=10 bucks
random wire, connectors(vtec wiring, o2 sensor extension, etc)= 20 bucks
JB weld to fix transmission case(crack)= 5 bucks
header flange= 12 bucks
pipe for extension of cat=11 bucks
oil, filter=15 bucks
Honda MTF=17 bucks(robbery)
plugs, wires=30 bucks
total so far is
1800 even
plus labor of my guy who welds=50 bucks
1850
and thats just for a B series swap
I didnt need axles, shift cables, mounts, and misc wiring, and also clutch hydraulics(our cars are cable operated clutchs, whereas H22's are hydraulic
idk theres a lot of work you have to do.
IMO go with a B Series, you already have the mounts, wiring is simple, add VTEC and get a PR3 or PW0 ECU get exhaust cut to length and your good.
