H22 DelSol Advice
Discussion in 'Civic and del Sol - EG and EK' started by Baylly, Oct 2, 2014.
  1. Baylly
    Baylly New Member
    Maryland
    This will my first official project and I'm looking for some advice as to what i'm going to need to swap out my d16z6 auto with an h22a manual , other than motor and trans?
    I was thinking of going to a local pick&pay junkyard trying to find an unscavaged Prelude and pick the engine bay apart. I also know I would need the wiring harness, shift linkage, and axles.
  2. get_nick
    Washington State
    you're going to need pedals, wiring, all sorts of shit. after market mounts and axles. it's a big project. i would get the engine, tranny, and ecu ASAP and start collecting the smaller stuff later.
  3. Briansol
    You'll need interior pieces from manual del sol as well to make the shifter work. And with the cable setup of the h22, you need to cut the firewall to allow the shifter cables through.
    more info:
    http://hondaswap.com/threads/h22adelsols-h22a-swap-guide.32252/
    A b-series swap is a LOT easier... if its your first project, it might be a better idea to start with an easier project
  4. Baylly
    Baylly New Member
    Maryland
    well the project I wanted to do was a f20c rwd swap but there is so little info out in the internets for it I kinda gave up on it
  5. Briansol
    Why do you want to do "the hardest thing possible" as your first swap? lol
    Start easy. learn stuff along the way, advance when the time is right.
    Otherwise, 6 months from now, you'll have a CL post up saying "buy all my shit for pennies on the dollar, i give up" and an empty shell of a hacked up car to the junkyard.
    You don't just 'swap in and make a civic RWD'. It's months of custom fabrication and re-enforcement and positioning and leveling--- and that's just to mount the block. Then there's routing a drive shaft in a car with no driveshaft tunnel.
    and 3242432432432 other things that will leave you hi and dry.
    Think realistic. Not "I want to be different"
  6. Baylly
    Baylly New Member
    Maryland
    Like I said I gave up on the dream but I want to swap the h22 in because it's easier and it fitsI just need a parts list to get started.
  7. get_nick
    Washington State
    that's pretty much your parts list posted above.
  8. phunky.buddha
    Dallas / Fort Worth, TX
    Yeah. Leave that to us dickheads that aren't afraid to cut and weld things that should not be cut and welded.
  9. get_nick
    Washington State
    95% of non B/H series swaps don't get finished. Everybody has a dream build, but not everybody has a dream budget.
