H22 EG6 Swap vibration help.
Discussion in 'HYBRID -> EG-EK / DC' started by TKNOLA, Jul 14, 2009.
  1. TKNOLA
    TKNOLA New Member
    I have a 1994 Civic Hatchback with an H22 swap, with front and back gsr spindles. OK, i was driving one day and i was going down a pretty Monster curve, and i bottom out pretty hard. I drove home everything was fine. The next day i got into my car, it started to vibrate when I exceeded about 55-60 mph. When im doing 60 mph and i hit the gas to about 50% acceleration. the car starts to shake pretty good in the front end area. I changed out my driver side outter tie rod and axle, but the shaking still continues. When im driving normal theres no shaking, but when i gas it to about 50% acceleration, or exceed 3500 rpms it starts to shake. Any ideas?
  2. Jared759
    Jared759 Well-Known Member VIP
    SC
    try an alignment.
  3. TKNOLA
    TKNOLA New Member
    hrmmm, but the steering wheel doesnt shake much, and if i let go of the steering wheel it goes straight with no pull to any side. its mostly like the ffront end area, like my dash shakes.. all my motor mounts are tight and good shape, i havent changed my passenger side axle yet could that be a problem? any more ideas?
  4. 97h22dxcoupe
    97h22dxcoupe senior member
    Coffeyville, ks.
    its probably your pasenger side cv axle, im 80% sure thats your problem,if this helped you out rep me up...lol
  5. TKNOLA
    TKNOLA New Member
    yeah, imma change that when i got out of class today i felt it shaking hard on that side last night, so i think its that too.
  6. 97h22dxcoupe
    Coffeyville, ks.
    the reason why im sure of it is because its your inner bearing on cv axle that is causing vibration at higher speeds,that happened to me a couple of months ago..
  7. TKNOLA
    TKNOLA New Member
    yeah, i think i remember when i changed my clutch, i busted the boot on the inner axle.. but...sigh... new orleans sucks... and the thunder rolls...
  8. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Not alignment. FYI....MANY Hondas don't need alignment due to wear and tear. New tie rods...yes they would make it necessary to do an alignment job. But I had a good friend that ahs worked for Les Shwabby for over a decade school me that my alignment was not an issue and the only way to aleviate the situation is usually only done by roatating the wheels.
    I say an AXLE too...but you need to jack her up to see....driving like this could cause a big accident...so I say keep that thing off the streets until its fixed
  9. TKNOLA
    TKNOLA New Member
    yeah im sure its not the alignment, if anything maybe a balance may have fell off the rim or something causing un balanced weight which prolly wouldnt cause too much of a problem enough to make my whole dash shake.. but damn Lol mines like earth quake when im doing like 80 at 4k rpms... wish i could fix it now, but its storming like crazy. makes me wanna do it in the rain cuz when the rain stops its gonna be so humid and hot.. =[
  10. TKNOLA
    TKNOLA New Member
    woot, no more shaking, had a _____ rip bout that long on my inner boot and the grease prolly all seeped out.. thanks yall, im new to the site, i dont noe how to rep O_O how do i?
  11. 97h22dxcoupe
    Coffeyville, ks.
    it looks like a little cloud at the bottom left side of my post,press it and there you go...
  12. DESPAIN
    flower mound TX
    thats funny cause same ting happend to me. i paid for ali9gnment didnt help. i rotated my tires problem solved
