H22 Forged pistons installation
Discussion in 'Engine Building' started by Asier, Mar 3, 2006.
  1. Asier
    Asier Junior Member
    I have an H22a engine on a Civic 92. I'm planning on installing Type S Cams and Eagle H-Beam Rods with Arias Forged 11:1 Pistons. A friend told that I have to install Sleeves on the stock block. Is that correct?
  2. mozzandherb
    mozzandherb Senior Member
    If you want forged pistons you have to re-sleeve. Do a search about that and you will see it has been covered alot, here and on H-T.
  3. driver1
    driver1 Senior Member
    the h22 uses a metal in the sleeves known as FRM or fiber reinforced mesh. the material will not except forged pistons. so in order to get around this there are 2 options. Resleeve the block or go with the new mahle pistons that have a skirt coating that supposedly allows you to be able to run the forged piston in the h22 without resleeving. I personally have not herd any good or bad about these pistons i just know they are failry new to the market. Although i would like to hear some feedback on how people have liked them. Hope this helps. Also as mozz said do a search this stuff has been answered numorous times.
  4. nismogod
    nismogod Senior Member
    Deltona, FL
    the mahle pistons were just reviewed in some import magazine, if i can find which, i'll let you know.
  5. hybridsol
    hybridsol Senior Member
    ohio
    tyler h (gold EK) uses mahle pistons on a stock bore, stock sleeve, closed deck, h22 to over 600whp
  6. 94CivicSlow
    94CivicSlow Senior Member
    B0ST0N
  7. mozzandherb
    It was the Honda Tuning mag the CB7 on the cover.
  8. nklabeek9
    nklabeek9 Junior Member
    Are you going nitrous?????? [​IMG]
    Vite' te pusite' trite'! :cry2:
  9. GSRCIVICTN
    GSRCIVICTN Lost in a sea of rednecks
    Nashville, TN
    The Mahle piston installation and dyno results are in the April 2006 Honda Tuning. Pretty interesting. Showed some pretty good results with some bigger cams.
  10. mozzandherb
    I didn't see the dyno results....hmm, I'll take another look at it.
