Hi,
I read a lotta threads on the H22 swap but some things are still unclear to me. I put a list together of parts I’ll need for my swap into my EG Civic. I’m not sure about some of the parts so here goes:
1.Prelude Front Clip (Can get it for like $ 1800)
2.Front and Rear GSR Brakes
Will the GSR brakes work with my stock civic lines or will I need the whole brake “system”?
3.GSR Fuel pump/Prelude Fuel pump
I thought of the GSR fuel pump. Will this work with the H22? Does the Prelude Pump fit in my civic?
4.H Series Rear Engine Bracket
5.H Series a/c Bracket
6.Hasport Engine Mounts
Will GSR mounts work or do I really need aftermarket mounts?
7.Hasport Axels/GSR Axels
I’m not sure if the stick GSR axels will hold up well enough.
8.GSR Gauge Cluster/Sir gauge Cluster
Or will the prelude cluster fit?
9. Manual to automatic Transmission Bracket (my car is automatic)
10.Prelude or GSR Pedal Assembly
I want to buy a brand new clutch and flywheel for the swap. But I’m not sure if I have to buy them for the lude or the civic. Can someone clear this up for me?. I assume the
Prelude ones.
How much can I lower the car for a good clearing?. Cause I heard that with the H22 it will scrape the ground if the car is too low
Sorry for so many questions.
Thanks
Prelude ones.
Thanks
