Quoted post[/post]]
Quoted post[/post]]
I just bought a rear ended 95 prelude. Im planning on take out the motor and swap it into my civic eg. What are some of the stuff that i will need to make this swap successful and what can i use from the prelude that might help?
Thank you
Tony
You are going to need the ECU from the the car because it plugs up to your eg and the resistor box for the injector so your car will start. Now you need to buy some motor mounts and axles. if it was my car i would do it right, so I would buy it all from Hasport if you buy cheap one you WILL run in to problem it will put u behind for a couple of days. And your wiring harness you use your civic the only thing you got to do is extend some wires. The h22 motor have EGR so you going have to wire that to your ECU and one more thing V-Tec unless you got vx si or ex EG you do not have to wire it. If you dont run vtec wire to ecu and im am goin to give you the pin out for Vtec and ecu. Im am going to go to the shop and look for the pin out ill will post it for you. So if I forgot some thing ill will post it with the ecu pinout.
