H22 Mini me swap
Dmolchanoff
ok i just got done with a mini me swap with a h23 block and a h22 head....it is one of the easiest swaps ive done there is a pin or a plug what ever u want to call it where the oil line is on the block, if you pull that its a go for sure...pull that out put the head on and wire up your VTec to ur controller and your vtec in about 5 to 6 hrs...depending on how long it takes you!!
