H22 Redline?
Discussion in 'HYBRID -> BA-BB /CA-CD' started by lsvtec hatch93, Apr 4, 2003.
  1. lsvtec hatch93
    lsvtec hatch93 Senior Member
    whats the redline on a jdm h22?
  2. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Redline is 7200, fuel cut is 7800.
  3. Accordturbo94
    Accordturbo94 Senior Member
    so your saying you dont have to shift untill or a little before 7800 on this beast? what mods would you have to do to make take the motor to rev 8200?? or wouldnt it make power that high anyways? assuming of course this motor would be NA
  4. D See 2
    D See 2 Senior Member
    Baltimore, MD
    i'm so glad someone else here knows the difference between redline and fuel cutoff.
  5. dohcvtec_accord
    The left lane
    The difference between redline and fuel cut isn't that tough to grasp. But you're right, it's good to know other people know about it. :)
    Anyway, your optimal shift point is going to depend on dyno numbers. You don't HAVE to shift until around 7800 rpm, correct. To make the engine rev to 8200, I'd probably upgrade things like valves, retainers and springs. I think the bottom end could handle it. However, I'm not sure if the stock H22 cams make power up there. You may need to get some aftermarkets (or MAYBE some Type-S cams) to realize any power above 7800.
  6. ludeconduct
    ludeconduct Senior Member
    Near Sac CA
    So your saying that even though this engine redlines at 7200, you could safley take it to 7800? Even though I don't really think its worth it, there is the occasional mis shift into the rev limiter and I always get a little freaked out whenever it goes that far into the red.
  7. Vexamus
    Vexamus Member
    Isn't it 7400 redline and 8100 rev limit on a USDM H22A??? Why is there a difference?
  8. dohcvtec_accord
    The left lane
    Hmmm don't really know. Maybe I should get myself a USDM P13 ECU. :)
  9. MPetro
    MPetro Member
    jdm type r h22 is 8900
  10. 1991AccoLudeCoupe
    1991AccoLudeCoupe Member
    G'ville, SC
    The redline on my 93 VTEC (as shown on factory tach) was 7400...with fuel cut-off at 7650. I made a habit of bouncing it off of F.C-O during a lot of my autocross races. She made power all the way up till the limit!
    I am gonna do some modifying on the same motor before it goes into my accord, so hopefully I will be able to rev to the mid 9's.
    Peace out homies!!! :D
    Theron
  11. 1991AccoLudeCoupe
    G'ville, SC
    I thought it was a Type-S :eek:
    Later, Theron
  12. AsiAnVenOm
    AsiAnVenOm Member
    anyone wannay help me solve my problem? it's a JDM h22a and P13....and the rev limiter bouncing off of 6800RPM while it's suppose to be 7800....it's an auto maybe auto tranny controller is doing it...?
  13. MPetro
    MPetro Member
    yea you were right about the type s, my fault, but it still redlines at 8900
  14. MPetro
    MPetro Member
    ok i take it back i dont know what i was thinking, maybe it's the f20 (S2000) that redlines at 8900, either way i'm retarded
