h22 sleeves in a b16 block???????
my friend at work is swaring that this is possible to do this, put h22 sleeves in a b16 block. use the b16 crank, block, h22 rods, pistons, and the sleeve. i told him i was pretty shure its immpossible but i figured i better ask here and make shure. so can you?
lol youre freind is a moron.
h22's are 87mm
85.5 is the largest you can go safely...
i've seen 86 on 1 race car. 1.
87, not happeneing.
even if you could fit a huge piston in there, the h22 deck height is different.. the rod will be the wrong length, won't bolt up to a b16 crank, an h22 crank won't fit in a b16, and even if it did, it would send pistons through the head due to wrong length.
