crzy2.2cvc
here it is
head
arp head studs
webb cams 435/250 475/250
skunk2 cam gears
blox titanium valve springs
spare head
factory cams and gears
2 intake manifolds
450 injectors
stock injectors
cometic head gasket
greddy timing belt
head resurfaced and hot tanked
megan header
block
arp rod studs
arp main studs
acl bearings
titanium rods
factory pistons
total seal rings
balance shaft removal
block resurfaced
h23 crank
line bored and honed at ERL
The rest
stock SI tranny
enjo mounts for an EG
p28 chipped to 9200
factory exhaust manifold
2 valve covers
stock flywheel
dont have
wiring harness
clutch
axles
flywheel bolts
i am asking 1500, possible trades but no garbage. really need money to pay some bills. i am located in the louisville area.
you can pm me, or call at (502) 643-6243, my name is Jeremy
head
arp head studs
skunk2 cam gears
spare head
2 intake manifolds
450 injectors
stock injectors
cometic head gasket
greddy timing belt
megan header
block
arp rod studs
arp main studs
acl bearings
titanium rods
factory pistons
total seal rings
block resurfaced
h23 crank
The rest
stock SI tranny
p28 chipped to 9200
2 valve covers
stock flywheel
dont have
wiring harness
clutch
axles
flywheel bolts
