H22 swap
92colesi
My Prelude is a 92 with an h23. I want to swap in the h22, but plan to keep my tranny. it's a 5spd, other than the motor and head, what else do i need to change? and can i get away with chipping my ecu and running an h22 map on the chip? thanks.
I don't know how chip-able the H22/23 ECUs are. It might be just as cheap to simply find an H22 computer. Other then that, you shouldn't need much else...
my other concern was motor mounts, mine are doing a fine job, do you think i'll have to change them to hold the new motor?
If the stock ones are fine you should be able to re-use them with no problem...
