h22 swap
Discussion in 'HYBRID -> ED-EF / DA' started by highrevnef, Jun 29, 2005.
  1. highrevnef
    highrevnef Junior Member
    i have a 91 si hatch with a b16 in it. i plan on swapping it for a h22. wut parts and obsticles will i run into? is the swap worth doing?
  2. mozzandherb
    mozzandherb Senior Member
  3. highrevnef
  4. mozzandherb
  5. trappd-in-859
    trappd-in-859 New Member
    burlington, ky
    I dont even think it would be worth doing unless you have a shit load of money and are a master mechanic or are willing to give it to someone to do and drop major bank. If you want that kind of power just boost the b16 because it will be alot cheaper in the long run.
    There is a sticky on this site that tells you the non recommended swaps. Heres the link http://www.hondaswap.com/forums/index.php?showtopic=29822
  6. B16CRX
    B16CRX Senior Member
    Greenville, SC
    boosting your B16 will produce more power and will handle better than a crx with an H22. Its really an overrated swap. If you want to spend osme money put an RSX motor in there.
  7. tangerinebeast
    tangerinebeast Junior Member
    handling with a h22 in a crx is no different than having a b16 the weight is not that much more
    here is a link with a guy that did a h22 swap in a crx on his own and doesnt have a great deal of money just a great deal of time and patients
    http://www.honda-tech.com/zerothread?id=711900
