h22 timing
Discussion in 'HYBRID -> BA-BB /CA-CD' started by bluenutz5, May 19, 2005.
  1. bluenutz5
    bluenutz5 Senior Member
    chicago
    ok my h22 in my dc2 has bin missfiring and idles weird sometimes...and is runing really rich...i have the stock p13 in and i dont know what to do...my buddy that works at honda says that it looks like one of my cam gears might be off by a tooth...does that mean i have to take the head off and adjust the gear or can i just turn the distributer to fix the timing?? wat can i do guys....?
  2. sihatchback_RL
    sihatchback_RL Senior Member
    EASY! turn crank to #1, pop out valve cover, check if your cam gears line up, if they don't, loosen tension bolt, line it up, put back on belt and tension it. turn crank again and see if cam gears line up.
  3. tab
    tab Super Moderator
    Aberdeen, Washington State
    If your cam gear is off by one tooth. It means that you will have to do a complete timing belt job. Your cams will need to be lined up, which means loosening your timing belt, which means removal of the auto tensioner. It's about a three hour job with the right tools.
    There is a special tool that honda has for the auto tensioner.
