EmEonE07390
I have been having a problem with my H22ed 94 Accord. Everything was running fine for about six months after the swap was complete. VTEC was kicking on hard at about 5200 every time, no check engine light, and redline was at about 8200. Recently, the check engine light came on and now VTEC will not kick on at all and the redline has decreased to about 6500 RPMs (where it was with my stock F22). The only code that is coming up is for an EGR valve. My mechanic checked the wiring and grounds and could not find anything. Replaced the solenoid, oil pressure switch, and swapped out the ECU and still no VTEC. Does anyone have any ideas I would really appreciate any help because my mechanic has run out of ideas!
Mark Piegari
EmEonE07390@aol.com
Mark Piegari
EmEonE07390@aol.com
