H22a?h22a4?
Discussion in 'HYBRID -> BA-BB /CA-CD' started by h22swap, Jan 24, 2003.
  1. h22swap
    h22swap Junior Member
    Can anyone tell me the main difference between the both of these engines, h22a h22a4. Also can anyone tell me what the best transmission that will work with a 97 h22a4. thanks
  2. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    H22A4 is the USDM Prelude engine. 190-195 hp and 154-157 ft-lbs depending on year.
    H22A is the JDM Prelude engine. 200hp and 161 ft-lbs of torque.
    What are your plans for the H22? Boost, get yourself an H23 tranny. N/A, get an H22 tranny.
  3. prelude92stype
    prelude92stype Junior Member
    a h22a1 motor has a obd1 as the h22a4 has the obd2 which is the biggest pain in the butt. But you can buy mods to work around it and convert it to a obd1 also.
  4. Ima2nr
    Ima2nr Member
    also, the H22a has a closed deck---which is great for lots of boost.
    you should base your decision on the OBDI or II factor though, cause it will cause you the most headache if you buy the wrong swap.
