h22a into 92 accord dx
Discussion in 'Accord' started by jeremy112683, Nov 18, 2009.
  1. jeremy112683
    jeremy112683 New Member
    Louisville, KY
    ok, ive read many forums, on many differant sites :confused:... i am still confused about the h22 swap into a 4th gen accord... some sites say its a bolt in plug and play swap, some say you have to rewire harnesses, change to diff axles, and some say you have to do stuff to the tranny mount?? what really needs to be done and can some one please point me into the direction where they got theyre CORRECT information???
    like, would either of these drop in and plug in?? no mods?
    TorontoJDM.com - Total Japanese Domestic Motor - JDM H22A OBDI ENGINE SWAP WITH LSD
    http://www.hmotorsonline.com/shop/sc2000search.cgi?what=page&item=30016
  2. BrutalB83
    Rochester Hills, MI
    If you get an OBD1 motor then the wiring should be easy. Basically you'll just need to add some wires for VTEC. It should be a bolt-in swap. You can use the Accord's mounts, but if the Prelude's mounts come with the swap I'd go for those. They're a little beefier then the Accord's...
  3. h22a91civichatchswap
    h22a91civichatchswap New Member
    Cedar Rapids, Iowa
    you will need axles for the h22a swap the mounts will line up but i'd use the ones from a prelude and the obd1 wiring should clip right in you'll need to add some wiring and pin in the Vtech in the Ecu the axles being for the lsd transmission other than that its an easy swap i did it in a '95 Accord Ex
  4. h22a91civichatchswap
    Cedar Rapids, Iowa
    oh sorry brutalb83 i pretty much said everything you did i didn't meen to copy
  5. jeremy112683
    Louisville, KY
    would the prelude mounts need any mod?
  6. jeremy112683
    Louisville, KY
    so if i go with lsd i would have to get diff axels?
  7. h22a91civichatchswap
    Cedar Rapids, Iowa
    yeah you'd have to get axles that fit that tranny and the mount shouldn't need anymoding if anything just use what in the accord it'll all mount the same
  8. jeremy112683
    Louisville, KY
    i thought the tranys on h22 and f22 were the same though?? so if the engine swap came with mid shalf/ half shalf, i could use them
  9. h22a91civichatchswap
    Cedar Rapids, Iowa
  10. BrutalB83
    Rochester Hills, MI
    No problem, buddy. Thanks for the extra info! :thumbsup:
  11. jeremy112683
    Louisville, KY
    brutal, im new on here, where do i click to send you some rep??
    1 person likes this.
  12. BrutalB83
    Rochester Hills, MI
    You click the little silver scale thing underneath my screen-name and avatar. I'll give you some too. Welcome to HS! :D
  13. jeremy112683
    Louisville, KY
    wierd, i only see that icon under my avatar, its not under h22a91civichatchswap [​IMG]
    either
  14. jeremy112683
    Louisville, KY
    stupid question!!! can i pull the motor out of a prelude? or do i want to buy a jdm?
  15. h22a91civichatchswap
    Cedar Rapids, Iowa
    you can pull one out of a prelude and take the mounts with it and that should drop right in nicely for you that'd be perfect only thing its a usdm instead of jdm thats it
  16. jeremy112683
    Louisville, KY
    thats what i was wondering, whats the real diff between jdm and usdm, doesnt the us have the same hp?
  17. h22a91civichatchswap
    Cedar Rapids, Iowa
    no the jdm has like 10 more hp because the jdm's don't have the emissions things like usdm engines
