You can try using an extractor, but with a heavy duty bolt like that it may not work. Another option would be to weld a nut on the end of the broken bolt and take it out that way.. that should work but be very careful when welding it..
i was told to drill and tap the bolt then to wind a bolt in because the crank bolt tightens the opposite way to normal bolt so in theroy it should untigthen as the other is tightened
right ive booked it in to my local garage who specilizes in hondas nissans and mazdas (he owns a drift spec s14a and a top spec rx-7) so hopefully the lude is on the road by weds fingers crossed.
