h22a swap engine code
dave_255
Member
hey guys i got a 92 accord automatic ex with a jdm h22a and automatic transmission. everything works fine and runs great except my engine light is on. it looks like it a throttle sensor or something what do you guys think it could be and can it be fixed. thanks guys
Double check your wiring. Then test the sensor.
You'll probably want a manual for this. I can't remember the numbers right off the top of my head. I think that it ranges from 5 volts to .5 volts.
