h23 possible upgrade
Discussion in 'Prelude' started by h23vteclude96, Feb 24, 2009.
  1. h23vteclude96
    h23vteclude96 scotty
    spokane washington
    my name is scott and i have a 96 prelude with a h23 in it. i just have a few questions about the internals of the the h series engine.
    i know they make type s pistons for this h23 but is there a differnce in compression with a type s usdm or a jdm or is there even a is it just a type s piston with no specification between?
    i plan on doing to my car.
    cams
    stage 2 crower cams
    cam gears
    some kind of adjustable cam gears
    valve train
    upgraded valve train to suport the stage 2 cam
    piston
    type s
    rods
    eagle rods h rods or something depends on what i find for the money
    crank
    h23 stock crank
    computer
    a piggyback system still need info about that may need some questions asked.
  2. BrutalB83
    Rochester Hills, MI
    The phrase "Type S" refers to the H22 engine from the Japanese Prelude Type S. They're not after-market, they're OEM Honda pistons. Using those will bump your compression up a bit.
    And I'd forget the piggyback and look into a chipped ECU instead...
