91civicsiracer
Ok heres the deal. I changed my tps sensor, changed the eacv, checked for vacuum leaks, checked the ecu, changed the o2 sensor, new fuel filter, new coil, timing seems to be fine, almost brand new nology hotwires, and just about every other possible thing besides changing the fuel pump. The engine kept surging from 1500 rpms to 1000 and when it droped it felt like it was going to die sometimes. The strange thing is that it ran ok as long as you were going, though it felt like it had lost some power. Even stranger is that when you would unplug the tps sensor it would stop surging but it would lose power, thats why I changed it but still the same thing, the wiring is fine its getting the proper voltage and the new sensor is at the right resistance. Now its difficult to get it to start, if you let the rpms drop down to idle speed then it sputters and dies. It seems like its not getting enough fuel, I could be wrong though. The problem has gotten progressively worse over time, from losing a little power to now not running without pressing the gas pedal and keeping the rpms up. So tell me what yall think it may be cause Ive just about given up on it. My best guess as of now is that the pump is going out
