Hcp Mounts
Discussion in 'HYBRID -> EG-EK / DC' started by pdqcrx, Apr 4, 2003.
  1. pdqcrx
    pdqcrx Member
    Va.
    Swaping a b18 in place of a d16. Did I read the part about the front cross member mount being a option correct. This is a three mount kit. If I want four mounts do I use the stock d16 mount on the b18 or the b18 teg mount for the front crossmember. This is my first swap I'm a tad confused.
  2. Civic_88ls
    Civic_88ls Senior Member
    everett, wasington
    If it is a three mount kit, then u dont need to use a front mount at all. for me the bracket that the mount bolted into was in the way so i cut it off with a cutting torch. is there nething else u need help on??? glad to help..
