head bolts
Discussion in 'Engine Building' started by INJEN78, Aug 8, 2009.
  1. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ive looked everywhere and cannot find the info..
    basically i need to know the lengths of a6 head bolts and z6 head bolts..
    im going minime and dont have the money for arp so im going to get oem headbolts..
    i just need to figure out what the differance is..
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    the D16A6 and the D16Z6 use the same head bolts - 10mm x 140mm
  3. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ohok..because this one guy was telling me i had to get d16z6 head bolts
  4. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ok so do i torque it to 22 ft lbs and then 48 ft lbs(a6) or do i torque it to 22ft lbs then 53 ft lbs(z6)
    im running the z6 head on an a6 block with a6 headbolts
  5. D15Beater
    D15Beater HNFTuning
    Concord N.C.
  6. TurboRex90
    TurboRex90 Golden EG
    Maryland
    ^ i was about to post that. lol
  7. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ok i didnt find what i needed ...next?
  8. jlicrx
    Colorado Springs
    22 and 53, like the manual says
  9. TurboMirage
    right ^^ and make sure you use the z6 timing belt too.
  10. INJEN78
    INJEN78 HS LEGEND
    OHIO
    yea i was going to use the z6 belt..i jus didnt know cuz the block/head combo
  11. TurboMirage
    on hondas you always use the top end components of the head you are using... studs/belts etc.
  12. INJEN78
    INJEN78 HS LEGEND
    OHIO
    lol yes i realize that..im saying i didnt know if i should torque to the z6 specs or the a6 specs..
    i had an idea that if i used z6 specs it might snap the bolt or strip the block..
  13. TurboMirage
    well the blocks are pretty much the same...
  14. INJEN78
    INJEN78 HS LEGEND
    OHIO
    thats what i needed to know..so i use the whole z6 top and the whole z6 torque specs.
