Head Light Prob
Discussion in 'ECU's, Electronics, and Tuning' started by chap_e77, Feb 2, 2003.
  1. chap_e77
    chap_e77 Member
    I have a 95 hb and one of the headlights went dull. I changed the bulbs and checked the fuses but the driver side headlight is still dull. does anyone know what the problem is. Any help would be great.
  2. E_SolSi
    check the connection points inside the plugs... they are probly dirty... carefully clean them up and this should fix the problem
  3. chap_e77
    chap_e77 Member
    well i just cleaned the plug with achohol but its still dull like theres not enough power going to it
  4. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    do you have access to a multi meter? Check the voltage and compare it to that of the other head light.
  5. BigJ
    I reluctantly had the same problem when I first acquired my car. Make sure there is a good connection in the plug and the wire is in good shape. Make sure the plug is a tight fit metal to metal for power, if bad you can purchase one at a junkyard and splice them. I did a lil different( purchased whole new hid harness).
