brian11to1
I dont believe so, I believe the head can be machined without disassembly. It will need to be cleaned hot tanked whatever before reassembly. But, Im more then likely wrong
Quoted post[/post]]
no disassembly is not required...
anytime i send out a head to get resurfaced i always leave the valves in it...
good idea to change the valve seals after hot tanking it but its not necessary...
local machine shop charges 75 bucks to mill a head
and 75 bucks to regrind the valves and valve seats to stock spec
150 for a brand new head, then just install new valve seals and throw it on...
i wasn't disagree'ing with you or putting you down...Which is why I said what I said. I had my P75 head milled and cleaned FULLY assembled.
Quoted post[/post]]
The lazy shops will not dissasemble the head. And that is bad. But your shop probably dissasembles, then does the valve job, then mills, then re-assembles. You have to dissasemble for a valve job anyway. If they do not dissasemble for a valve job you need to change shops, because you are getting a shitty redneck valve job.
Quoted post[/post]]
Quoted post[/post]]
What's up? I need to get my cylinder head resurfaced and I figured I'd go ahead and take .01" off to get my Z6 up to about 9.4:1. Do I need to disassemble the head for this? I'm asking because I've never had this done.
Just in case:
D16Z6
75.5mm bore
Comp springs and retainers
Comp 59300
