Header info
it will but you have to use the civic catalytic converter. But if you have an Si header lieing around and you want to use it to save cost just go to a muffler shop and have them make you up a straight pipe to connect it to your exhaust.
Deck heights r different between the B16 & B18
header
it will fit.... i got a stock exhaust manifold form a b16 in my ls and it fits... like he said ill u need is like a test pipe to conect it to ur cat,...
I guess I was just one of those flukes then cause I used to think that all b series headers would fit, but I just did a C5 swap and my DC headers won't clear the bottom, so I had to take the stock headers off an ls to use for now
