headers install question
Discussion in 'Integra' started by PUREKDM, Jun 12, 2007.
  1. PUREKDM
    PUREKDM New Member
    if fed ex is right, i should have a box with dc sports headers sitting at my door tomorrow...if this is the case, and i should try putting them on, will there be anything in my way i should take out first i.e. ac, power steering or anything that i cant even imagine? thanks in advance!
  2. 99sidude
    Ohio
    no it should be pretty straitforeward. I guess you could remove your stock heat shields if they are still there.
  3. formby
    formby learning in progress
    well youll 1st have to figure out what youll do with the other HEADER...
  4. eg6sir
    simple process.. take the o2 out first if you can.. then unbolt the stock manifold from the cat.. .. then unbolt the downpipe.. the top section is a heavy bastard.. depending if your new header(- the S) is one piece you may need to have the car jacked up higher to get the header in the bay.. it'd be hard to maneuver from the top
  5. PUREKDM
    PUREKDM New Member
    do you guys know the length, thread, and pitch of the head bolts? i'm thinkin i'm going to want new ones so i don't have pretty stainless headers with rusty ass bolts in there...
  6. formby
    go to the acura dealer
    14 90001-P30-003
    BOLT, FLANGE (8X25) 7 2000 INTEGRA 2.43 1.94 Qty: [​IMG]
