heat problem on my car
Discussion in 'Civic and del Sol - EG and EK' started by 2low93, Feb 29, 2012.
  1. 2low93
    2low93 New Member
    i have been having heat problems..there is no air coming out of the vent the blower aint coming on. I have checked the fuse and the relay those are good. took the the blower motor out and hooked it up to a battery and it works. took the blower motor resistor out it is good. today i took out the heater control panel and check the the blower motor switch thats good but when i check the connector for the blower motor switch i wasnt getting any volts out of it now since there no voice the relay is wat power the switch could that be out if u know anything bout this lmk what i can do to fix.btw it on a 93 honda civic ex
