heat????????????
kc_boss_816
kc_boss_816
i have an 92 honda hatch i just bought it and the motor was swapped out and its about to be winter and the heat doesnt work..do anyone know the possible causes of why the heat dont work or know what i can do to get it working.........(message me with any answer's that could help me out thanks)
there are a few reasons why the heat might not work
1 during the swap they dind't put in heater hoses (just looped it) and you will have to put them in yourself (not too hard)
2 your heater control valve (on the firewall, below the fuel filter) got broken or isn't working, causing the coolant to not flow. (not hard to change)
3 your heater core is clogged and needs to be replaced
4 you don't have enough coolant in the engine
There could be other things, but those are a good few things to check
ok i will check those things out
