Help 1998 ECU 1995 LS
Discussion in 'ECU's, Electronics, and Tuning' started by rajb0929, Nov 12, 2002.
  1. rajb0929
    rajb0929 Junior Member
    I have a 1995 Special Edition , it comes with a ls motor i have just recently swapped it with a 1998 LS motor.. the tranny switches alil hard and i was just curious if there is some way i can fit that 1998 ECU into the 1995 Body .. i know one is OBD1 and 1998LS is OBD2 .. but is there anyway i can put that 1998 ECU by jumping the wires somwhere .. or is the computer getting used to the new tranny ... the 1995 ECU is getting used to the new tranny ... Thanks
    :blink:
  2. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    Is this an auto?
    Did you remember to top off the fluids?
  3. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    I believe that all SE's are auto's. I know at least the Accords are that way.
  4. dohcvtec_accord
    The left lane
    Oops, my bad. Just the Accords. Manual Integra SE's came in 5-speeds.
    I've said it once and I'll say it again: Screw you B-series boys. :lol:
  5. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    You're just jealous that we can get more of our cars in manuals. :D
  6. dohcvtec_accord
    The left lane
    Jealous of a lawnmower with a variable valve timing system? Naaaahhhhhhhh.
    :wall: :D
  7. pissedoffsol
    LS doesn't have VTEC moron.
    anyway- use the SE ecu... run an obd 1 dist. and injectors... an di think thats it, right?
  8. dohcvtec_accord
    The left lane
    Yeah but an ls/vtec DOES does VTEC.
    Moron.
    :D
  9. rajb0929
    Its auto .. so i should run the 1995 ECU and just put on 1995 Distributor and injectors on the 1998 Engine???
  10. lsvtec
    That sounds right to me.
