HELP? B15 -> B16 Vtec
Discussion in 'HYBRID -> EG-EK / DC' started by GermanCivic, Oct 29, 2002.
  1. GermanCivic
    GermanCivic Junior Member
    Hi! :)
    SORRY! I men the 1992-1995 engines! B15 and B16 I think.!!
    I have a Civic with 1.5l 90HP and got a 1.6l 125HP Vtec engine with transmission + Ecu ! Now my question, can i swap the motor 1:1 ? What do I need new? Or can i deduce those 2 machines?
    Thx for all information!!
    Felix from germany :lol:
  2. B16
    B16 Super Moderator VIP
    yay area, CA
    it is D15 and D16, B motors are DOHC :)
  3. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    The Full swap should not be too tough. I assume you are talking about D series nonVTEC to Dseries VTEC.
  4. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    the only thing that will realy be tough (and it is fairly simple) you will have to wire for VTEC.
  5. Baker
    Baker Senior Member
    Schaumburg, IL
    screw that, why does everyone wire? Just get the proper harness for the engine. It eliminates most wiring
  6. E_SolSi
  7. Jeef
    Jeef NO MA'AM Moderator VIP
    Why spend many hours to swap harnesses when it takes under 2 hours to change all the wires that you need to change.
  8. Baker
    Baker Senior Member
    Schaumburg, IL
    umm, swapping a harness with the motor in the car takes only a few hours. When the motor is out of the car it take almost no time at all.
  9. pissedoffsol
    MOTOR harness is easy- the DASH is not- and guess where the VTEC wires lie-- in both. have fun re-wiring your dome light, your radio, your CEL, your spedo lighs, your glove box light, blah blah, or add 3 wires.
    your choice.
  10. djyox
    djyox Senior Member
    Twin Cities, Minnesota
    I have no idea witch is the better way, but I'm going with this sales speach...... :werd:
  11. GermanCivic
    Hi thanks for your informations, has anyone a guide which cables i have to change? I thought about buying the proper harness..
    thx!
  12. Baker
    Baker Senior Member
    Schaumburg, IL
    ok, run the dash wires buy the engine harness, I don't trrust running to many wires under the hood, theres a lot going on in there tempature and vibration wise and things can come loose
