HELP EVERYONE ITS MY 1st HONDA BUILD. IT WONT RUN NOW
Discussion in 'HYBRID -> EG-EK / DC' started by kuntrychris, Apr 25, 2011.
  1. kuntrychris
    kuntrychris New Member
    I have a 93 Civic Dx with a B16A3DOHC Vtech. Which i bought like this ok I know its been swap out to have this engine in it. Shortly after i bought it i spun rod bearings so i pulled the engine and rebuilt it. I had the crank ground .030, put YCP B16A High Compression Pistons with Teflon Coated Skirts 11.9:1, Nippion racing rings, King .030 under racing bearings & thrust washers, 4 NGK Spark Plugs For High Compression Engines R5671A-8, all new gaskets and seals, new oil pump and gates racing timing belt and racing water pump and new header. i didnt do any work to the head or mess with the ECU which is Auto B16 P23 Spec written on it. Now its back together and in the car. It fired and ran on the first start up then flooded out and died. cleaned out extra fuel out of engine and started it up again and it ran till i turned it off. NOW IT WONT START @ ALL FOR THE LIFE OF ME. Its getting fuel to the injectors, its got spark, and Ive set the timing i dont know how many times. By all rights it should run. WHATS WRONG WITH MY CAR??????????????????? PLZ HELP ME EVERYBODY I DONT KNOW WHATS WRONG. THIS IS MY FIRST HONDA BUILD
  2. Bob Vila
    Bob Vila ɐןıʌ qoq Admin VIP
    Bristol, Ct.
    Did you check the blinker fluid?
  3. Drake
    Drake Well-Known Member VIP
  4. Matts96HB
    Matts96HB . Moderator VIP
    its flooding out? are you pulling spark plugs to check the cylinders?
    is there gas in the oil?
  5. kuntrychris
    yes i have pulled the plugs. no its not flooding out. ive got it to start but i have to hold it wide open.
  6. Matts96HB
    holding it wide open just opens the throttle plate. the ECU in the car is not the correct ECU for your application, id suggest just getting a chipped obd1 ECU and having it tuned. you have enough mods to benefit from doing so.
  7. kuntrychris
    When i hold it wide its get just enough fuel to start and run alil bit but if i let off the gas itll die. it acts like it isnt gettin enough fuel now. wat cud cuz tat
  8. Matts96HB
    no, its not a carbureted. mashing the gas on the floor is only opening the throttle plate. not adding more fuel
  9. dc4dude
    dc4dude Member
    chicago, il
    maybe a ripped diaphram on the fuel pressure regulator.... if you have to floor it to get it to run, that means you have too much fuel, not enough air... sounds like a bad fuel pressure regulator issue...by opening up the throttle plate, you are trying to match the amount of fuel you have with air... check it out..
  10. stoopidb18eg
    stoopidb18eg New Member
    I really dont think its the blinker fluid. That wont keep the car from starting. It ended up being the muffler bearing on mine.
  11. Magana559
    Magana559 The Warden
    fresno Ca
    The ecu will read WOT and spit out more fuel while cranking. so your adding more fuel and air while cranking.
  12. kuntrychris
    i can get it to idle @ 2000 it wont down down below 2000 or rev up
