help help need a quick reply
Discussion in 'General Tech and Maintenance' started by mintoxik, Mar 18, 2008.
  1. mintoxik
    mintoxik Member
    Oceanside
    hey fellas so i have a jdm b16a block i found a b18 head from a ls integra will it work or should i not waste my time im new to the import world so thnx guys
  2. evokilla@nadsny.com
    evokilla@nadsny.com New Member
    it will work any b series anything will go with any other b series something
  3. mintoxik
    mintoxik Member
    Oceanside
    but will it be worth my time and can i make it vtec?????
    my car is in the works right now it got stolen now im on the rebuild thnx :)
  4. evokilla@nadsny.com
    you can make it vtec with a vtec head...not with a ls head
  5. mintoxik
    mintoxik Member
    Oceanside
    .......so theres no way i can make ls head vtec huh then what is it good for????
  6. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    vtec is for gas economy. if you want to go fast, just get cams that are just as agressive as vtec lobes...
    companies like crower can custom make you cams to any specs
  7. mintoxik
    mintoxik Member
    Oceanside
    so i should get the ls head if i wanna go fast well i can honestly say thats a first ive ever heard can u give me a ball park of numbers that would be great but thanks for all the help fellas
  8. YBLEGAL
    NW Indiana
    What I ment is if your only worried about running at the track and making quick quarter passes, then you can get away with just large, agressive cams in a non-vtec head. Blanco is correct tho, you will lose low end power.
    If your a street car, and you can find a vtec head, then it'll work a little better for your application. I'm not sure what goals your going after, or what numbers your wanting. Take a look at our reference section and you can look at what motors have what features, along with a lot of other great useful information.
    then get back to us
  9. BrutalB83
    Rochester Hills, MI
    :werd:
    You can make this combo work, but it's kind of retarded honestly. A straight B16 or a straight LS would be much preferable to an LS head on the 1.6 block.
  10. mintoxik
    mintoxik Member
    Oceanside
    thnx i was just trying to get a quick fix so ican get my b16 in my car but forget it ill just find a b16 head
  11. BrutalB83
    Rochester Hills, MI
    Not exactly true. The B20/B21 from the old Preludes isn't compatible with any of the other B-series engines.
    Good call. You'll be much happier with the B16 head. The LS head doesn't flow very well in stock form, but at least it's usually paired with a 1.8 block, so it makes decent torque. Paired with a smaller B16 block though, you'd be getting the worst part of both motors.
  12. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    Smart man. You listened. Best of luck on your build. :D
  13. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    "VTEC is the #1 choice for Honda enthusiasts!" This is what I heard some old fart bag say at HIN six years ago. Everyone laughed it off like it was nothing... now look how far it has gone today... :)
  14. Luis998
    Orlando, Florida
    I wonder how long the LSVTEC concept has been around. I'm sure no one ever imagined that either.
  15. mintoxik
    mintoxik Member
    Oceanside
    ill let you guys no how it goes i have a long way to go cuz my car was stolen now i have some reason to take it all apart and go from ground up if u guys have ne idieas it would help alot thnx again guys
  16. Luis998
    Orlando, Florida
    My friend, I really do wish you the best on everything, as I have been there. My car was stolen once in 2000 and broken into three times in the past two years. Best of luck.
