help i want a zc in my dx ef and make it obd1
Discussion in 'HYBRID -> ED-EF / DA' started by dok, Oct 19, 2006.
  1. dok
    dok Senior Member
    ok guys i have a really low buget and want a sohc zc in my ef but the dam car is a dual port and the engine is a mulit port and to top shit of i want to turbo it and the dyno around me will only tune it if its it a obd1 """""" please help""""""""""
  2. ef8
    ef8 Junior Member
    What do you want help with?You didnt ask anything.
  3. nikozai
    nikozai New Member
    wow 600 posts and you post THAT. lemme guess, english isn't your first language? =)
    You can easily make a DOHC ZC OBD1.
    Rywire.com carries EVERYTHING you need.
    Wiring conversion, OBD1 distributor, OBD1 chipped ECU etc... Not sure what else to tell ya except buy the engine LOL
  4. dok
    dok Senior Member
    dam and i see you are holding your dick at 4 in the morning a lol!!!!!!!! i just wanted to know how to make my dual port into a muti port and make it a obd1 by soildering the obd1 pulgs and running wires to the engine bay
  5. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    Search dpfi to mpfi into this search engine and on Honda-Tech and you will be enlightened with all the information you want.
  6. byebyebaby
    byebyebaby Byaaah!
    Frederick,MD
    as far as the obd1 thing goes u can either spend all day converting eack wire yourself or get the conversion harness. you will also need a obd 1 ecu
