Help Me
Discussion in 'Engine Building' started by civ92hatch, Jan 16, 2003.
  1. civ92hatch
    civ92hatch Junior Member
    hey guys,
    im proly the newest member ryte now, but i need to kno wut the difference between a B16a and a B16a2 is????? <_<
    im not a noobe @ this either , so plz b nice :D
  2. B16
    B16 Super Moderator VIP
    yay area, CA
    well, for starters you can try spelling out whole words :) but to answer your question, the B16A is obd1 and JDM and B16A2 is obd2 and USDM
  3. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Does babelfish.altavista.com translate any of that?
  4. E_SolSi
    at the top of the page you will see the Reference tab
    click it
    then you will see Engines
    click that
    now you will see a list of engines look for the ones you want to know about and click on them ... there you will find basic info on each engine
  5. 86CRXBigGoKart
    86CRXBigGoKart Junior Member
    Also, B16A1 ANd B16A2 are different for a few internal reasons..i think B16A2 has alittle higher compression (Not 100% sure about this) but I know that B16A2 uses a Hydraulic clutch, and B16A1 uses a cable type.
  6. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Then you should know how to spell.As for the differences they are in the reference section.
  7. D See 2
    D See 2 Senior Member
    Baltimore, MD
    i'm not sure about compression either but i know the cam profile on the b16a2 is a little more agressive than the b16a.
  8. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    well theres an assload of b16's
    the b16a the sirI swap, strictly jdm motor 10.2:1 compression 160 hp
    the b16a sirII swap- also jdm but with a 10.4:1 compression and diff cam profile 170
    then the usdm b16a3 (delsol VTEC) and b16a2 (99-00 si) 160 hp
    then if you wanna get technical
    b16b - civic type r motor.... yeah
    and the b16a1 edm motor, outta the vt1, but fuck that thing
