HELP "My buddys ZC Civic !!" HELP
Discussion in 'General Tech and Maintenance' started by Bart, Oct 15, 2002.
  1. Bart
    Bart Junior Member
    Hey Yall
    ok listen my buddy just bought a Honda Civic Si with a ZC Motor...
    ITs weird cuz he drove it for a month stright without problems and yah theres a problem....
    he was driving down the 401 and it turned off
    so he try'd to start it and it just wouldn't so after getting it towed for 150$ he took it to Honda too see withs wrong with it they tested it...
    he ended up paying 71.55$ for nothing... all inspections...
    Can someone please help me out!!
    its stalls every couple of weeks usually after driving long or pushing it hard..
    it has a D16ZC motor.
    -The idle fluctuates in the morning unable to duplicate fault..
    the y inspected the
    -plus
    -cap
    -rotor
    -and coil.
    All appeared to be in good condition and are all properly working.
    they cleaned the throttle body
    they said the idle valve not hooked up to cooling system , causing fluctuating idle (throttle playe does not close all the way?)
    right upper ball joint worn
    shifter rob worn out and loose..
    right inner cv boot split open...
    both rad hoses cracked.
    both axle seals leaking
    seatbelt buckle recall parts ordered
    ________________________________________________________
    All for a price of $$82.28 out the door lol its gay...
    ight so what do you all think??
    PLEASE HELP ME
    email me @ littleshorty4life@hotmail.com
    and tell me whats the problem... :worthy: :worthy: :worthy:
  2. Jeef
    Jeef NO MA'AM Moderator VIP
    Check the wiring, grounds, test the main relay, make sure that the screw did not fall out of the distributor rotor.
  3. Havok
    Havok Senior Member
    Florida
    Why did he buy an Si with a ZC motor?...They are about 13 years old. What are the rpm's doing when the car stalls? (high/low)
  4. djextremity
    djextremity Senior Member
    in your rearview mirror..wait..
    You only need to post in one forum..especially if you are receiving quality answers for it..
