gettocrx
Member
Hey again! I'm planning to go with bigger injectors on my SOHC CRX DX with si head thats boosting 5 psi with a garret t3. I have a MSD high flow fuel pump with a 8:1 FMU. I was told that the 1st gen DSM 450cc stock injectors will work. What will I need, in order to run these injectors?? I also want to boost a little higher. What would be safe?? (thinking of 7psi)
Thanks again for all your help!
