I have an obd0 B18A running a Zdyne SECU and Zdyne 450cc injectors. I want to replace the injectors with 750 or 1000cc and was wondering which type of injector I need to match the current setup & harness plugs?
Thats what I was thinking, but what about the harness? They are different depending on the injector right?
the manufacturer usually will send you the correct plugs with the injector if you ask for them rc and precision are great injectors just as a bit of info to u.. 1000cc injectors from either can be had new for ~$300
depends what you have now.... some are pretty iniversal, some come with pigtails and will need a splice-in.
