i just put a 95 ls into my 92 hatch but the motors idling high and running very rough what can i do to get it to normal. also can i use a 95 integar axle wit the abs ring still on it even if i dont have abs? thanx
adjust the Idle screw, which is on the intake manifold/ usally on the throttle body above where the intake tube connects. it is a recessed flat head type screw. to be safe with the axel get a none abs one.
