Ok here is the deal. I just replaced the head gasket on a 93 Civic HB DX (auto). I went to crank up it cranks but will not start. So I used one of those compression testers that screw into the spark plug socket and got 90lbs on all 4 chambers. I then tested all my wires and spark plugs. 1 was not sparking so i replaced it. Now it still won't start but it will crank (wah, wah.wah) What now?
1. Is 90 lbs good or do i need more?
2. Is it fuel, if so how would i check to see if it is getting it or not?
3. WTF could it be
3. WTF could it be
