racingtopher
Member
My swap still has some problems. OBD1 B16a in a '91 civic Ex.
When I start from a stop, if i full throtle it, it seems slugish and starts off to a slow start, but picks up after 3000 RPM.
But when i slowly give it gas and i release the clutch, it seems like its going to die.
The problem happens between the range of 1000-3000 RPMs
So what i have to do is just dump the clutch at 3000, like im at the tracks, but i don't want to wear my clutch out.
Another problem is that after driving it, I shut off my engine, and when i try to start it later it idles very low, sometimes where it is going to die. Then I give it some gas, and keep the RPMs at 1000 for like 30sec, it startst to idle fine.
Pleas help me, my car has not been happy with this swap for almost a year now.
Parts already changed.
EACV
Plugs
Cap/Roter
MSD wires
Battery (Optima Red Top)
Some vacuum Lines
And does any one know which pins on a OBD-1 pr3 or any obd-1 ecu, to jump to see the engine codes?
Also does any one have a vacuum line diagram for the OBD-1 B16a
FYI: Engine is B16a out of '93 Xsi teg, so OBD-1 pr3 (I'm positive). grey plugs and all.
Thank you,
Chris
EACV
Plugs
Cap/Roter
MSD wires
Some vacuum Lines
Thank you,
Chris
