ok i have a dohc zc is it true i can yous gsr head studs the part number for the studs is 208-4303 ARP i just have to cut a 1/2 off of the middle one on the intake side right i hope this is true....
the ARP head studs that work in the DOHC ZC are part no. 208-4601 which are for the ones for the B16A and the 92-93 Integra GSR B17A1 engine - the B18C1 GSR head studs 208-4303 are 9mm too long - you only need to grind a couple of mm (not 1/2") off the bottom end of the center stud on the intake side where it is close to the camshaft
