HELP!!!
Discussion in 'HYBRID -> EG-EK / DC' started by mattcalica, Oct 21, 2002.
  1. mattcalica
    mattcalica Senior Member
    yo, can i use b16a connecting rods, with a LS/vtec setup??? can i
  2. tb820
    tb820 Junior Member
    Why would you want to do that? You go LS/VTEC for the low end torque that the LS gives you and the highend power that VTEC has. Installing b16 rods when you have the b16 head installed will ultimately make it a.... b16 motor.....
  3. farmer_jason
    farmer_jason Senior Member
    florida
    it wouldnt even make it a b16 ther'll be no compression plus the journals r different on the crank
