hf radiator question
Discussion in 'HYBRID -> ED-EF / DA' started by kricket3000, Oct 5, 2008.
  1. kricket3000
    kricket3000 New Member
    i'm swaping a b18 into my crx and i put a nice hole in my stock radiator. should i replace it with the same one or something bigger? thanks
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    run an integra rad..you can just use the hoses too without having to mod them..
    just dent the hood support
  3. kricket3000
    dent the hood support???? please explain
  4. INJEN78
    INJEN78 HS LEGEND
    OHIO
    the skeleton under the actual hood,,the braces or whatever,theres 2 spots itll hit but its not bad
  5. kricket3000
    I have a carbonfiber sir hood, how bad does the da radiator hit? if i stay with the stock rad what is the hose mod?
  6. INJEN78
    INJEN78 HS LEGEND
    OHIO
    if you have carbonfiber just cut a little out where it hits..and if you stay stock the stock hoses are too small for the water necks on the motor,,you have to "sleeve" the hoses and put bigger ends on
  7. kricket3000
    got ya, thanks again
  8. efhondakid
    Akron-Canton, Ohio
    Im using the stock radiator and D-series hoses, I stretched them over the B-series water necks. I havent had a problem with bursting hoses or over heating or anything like that. :dunno:
