hf to ls
Discussion in 'HYBRID -> ED-EF / DA' started by kricket3000, Jul 2, 2009.
  1. kricket3000
    kricket3000 New Member
    hey guys, been searching around and i'm looking for a vacuum diagram for a b18a1 into a 88 crx hf. any help would be great, thanks
  2. kricket3000
  3. kricket3000
    o well, i'll just buy a neon!
  4. D16SiHatch
    D16SiHatch New Member
    please god don't do that :|
    this is how i have them routed in my b18b1 in my si. not exactly like your a1 but should give you an idea. the blue line is where the map vacuum line would go assuming i didnt have a tb mounted map sensor. the yellow is for the purge solenoid that goes to the evap canister. the thick red vac line outlined with yellow goes from the vac canister, to the top of the throttle body. the dark orange line behind the tb goes down to the vac purge valve. the light blue vac line is for pcv, and on the farthest to the right the brown outlined vac line goes to the fpr.
    i included the vacuum routing diagram for the a1 as well.
  5. kricket3000
    if it was not gay i would hug u,:D thank u vary much
  6. D16SiHatch
    ha not a prob man. glad i could be of some help
