high compression and fuel management
Ignorant import guy
If high compression pistons are installed on a d16 is fuel or engine management required? Also are forged rods needed?
Well how much should a tune fir that typically cost? Just so I know if I'm getting ripped off. And will I be able to drive an hour away on the pistons without tune? And last noob question will I need bigger injectors?
Dyno time alone usually costs about $75-150 an hour (dependeding on the area). And then the time of a good tuner usually costs about the same.
