High compression B17
Discussion in 'Engine Building' started by SpoonTuNed, May 26, 2005.
  1. SpoonTuNed
    SpoonTuNed Senior Member
    I recently picked up a B17 block freshly rebuilt. Im looking to go all motor with it and was wondering if anyone could help me out with what head i should use and what kind of compression i'll get going with a gsr head vs. b16, also does the b17 have oil squirters???? thanks
  2. phunky.buddha
    Dallas / Fort Worth, TX
    GSR will give you slightly higher compression, but only about .2 (most likely less) more than the B16 head. Your B17 head is the same as the B16's, so there's no reason to change it. You don't have oil squirters.
