hey, my motor is acting real weird, when i start it up the oil pressure shoots up to about 60psi and when i idle its at 25psi, and while i'm cruising at 3 grand, it sits at 50psi. when i go about 3500rpm it goes up to between 70psi-100psi, i'm pretty sure nothing is wrong with my sender, or my gauge. before it would idle at about 15psi, and cruising around 20-30psi, and when i hit vtec anywhere between 65-80psi. idk if those are optimum ranges, i'm just not sure. its an h22a4 with underdrive pulleys, and thats about it. if anyone can help me let me know. thanks
